Is this happening to anyone else????
  • Replies 33
20 silver ,I'll let you guess the manuf. Just started and had 20 of the 40 some windows cut...
switched over to solar gards silver , no problems
This happened to me last January with a dual reflective 20%. Got 1/3 of the job done in 6 hours, which was longer than I expected the whole thing to take. It was below zero and the insulated glass was cold. Got the film replaced (same stuff, different lot numbers)and returned and finished the job in a couple of hours. Good thing business in Michigan is pretty slow in January.
they put too much tension on the film when they apply the hard coat ,so that can cause a couple of problems, it wont lay flat the other effect you can get from that is obsessive fingering after the install
seen it before. I use Suntek 35BR everyday on a special project and have the same problem. i found if you use like, scott blue paper towels and dry the edges very well the problem is lessened
    2. 7
    6. 11
    7. 11
