60 windows in 3 hrs.
H.G.
:poke .....3 min a pc, must of had them pre-cut......?
Yep ... but just 1" over , line up top , tack down , cut in and squeege. Like I said , they were pretty clean frames too. :lol2
I will cut edges (for shellac , silicone whatever) and clean the whole set , hose and wipe down debris then clean the next set while the 1st one "drains" . By the time I get done with the second
one the 1st set is ready .I start at the top and finish squeegee all the way to the bottom. I lay up 6 panes starting at the bottom going up and tack , cut , finish. then on to the other 4. By starting at the bottom , nothing can drop onto the pane below. I make sure my tank is charged so it puts more of a mist out and use as little water as possible.
Well actually it was 30 but they wanted to tint them on both sides , frost. I love f/p 's
Whoever varnished or shellacked the frames did a good job.
Kinda creepy. I wonder what goes on behind those doors.
It's a changing room at a retirement center. You don't get the "shadow" effect you normally get with one layer.
Guest Malcolm E Boo
Answer my question that I never asked.
:nope:boogie Ohhhhh! Sorry pardner , " I wonder" usually implies a question . :lol
