Hard card-Squeegee sharpener tool
I got this in today from EWF, and it works great. I know some sand them down, and i tried doing that also. But this thing makes the hard cards new :whisper Thank's again EWF.
I got this in today from EWF, and it works great. I know some sand them down, and i tried doing that also. But this thing makes the hard cards new :D Thank's again EWF.
I agree, that is a great tool. One of our best sellers.
always wondered about those. does it work for the lil chizzlers?
It can, but the edges are rounded so it is hard to slide through smoothly. One more note also is that the more you trim, the thicker the edge becomes. For some that is a negative.
we got one from EWF a while back and it has worked well. As it was said before the more you shave the card, The thicker it gets but in some cases it can also be a help because the edge has more stability to withstand pressure.
Guest shadeking
Its a great tool for your tools, and some sanding sponges your good to go! I also like the sandpapers you can find in the toy model dept.
