megane 3door 04-09 front windows, door cards?
Guest james#70
Guest james#70
What do you guys do?
Would ideally like to remove the bottom gasket to get a better install, anyone know how these gaskets come out or are they fixed to door card?
Or should i remove door card, but im pretty sure on these the door card splits in 2, has a inspection flap that opens and im sure the door card is attached to the reg?
Guest james#70
Well took the job on. Options are either remove window, tuck gasket, or slide under gasket. I removed window as was easy, window out in 5mins, 2mins now i know how. Tinted right to the edge, shaved edge, back in and looks spot on
