E90 Window Fault
Guest dagz
Did an E90 coupe today. Pulled the strips from the top of the doors, so didn't remove panel or undo a single screw or anything. When I'd finished I went to put the drops down to put the strips back on, and the drivers window switch was dead. Passenger one worked fine. I got the window down and up again with the remote locking control. But the switch is still dead. Very minimal water was used in installation, I would be VERY surprised if it was a fault caused by water, and as I said I didn't removed the panel, just popped the strip out cleanly and easily.
Any ideas?
Guest tint325i
to be honest with you i have soaked switches in these a few times and never had a problem, so doubtfull water is the problem, no idea, try the usual battery disconnect thing, or try toget it plugged in, thats where a friendly bmw dealer is handy
Guest maddtinter
I'd be taking that door panel all the way off & checking the connector before anything else. Maybe it has a bad clip & slid out when you were moving the panel around. :lol6
Maybe a individul fuse for that switch?
    2. 7
    6. 11
    7. 11
