rubber bead
Guest woodbs
I have a couple 1 inch pieces that I will put in the top corners when I pull the sides, top, and bottom....helps keep it from bouncing. Then just pull those out right as you trim that area...
Guest VOLTRON
I trim gaskets when it is needed. Alot of people pull gaskets and I have done it before but I dont like the glass bouncing around on me and dont want to risk the glass breaking if it falls off the rubber blocks if there is even rubber blocks there.
Guest scottydosnntkno
i pull the sides and bottom. Butt the factory edge up to the top if possible since you won't notice a tiny gap up there. Plus like as has been said it'll keep the glass from falling/breaking.
Guest VOLTRON
I trim about an 1/8th off, really just that lip that most rubber gaskets have where it starts to angle horizantal to the glass. And make sure its a clean cut, dont cut sections at a time. Just one uniform smooth cut from top to bottom.
