removing small creases
Guest alexbolt
Guest alexbolt
Im new to tinting but have some good dry shrinking down when i go to wet shrinking i notice tiny small creases here and here i noticed if i heat the crease up till the tint around it starts going nuts and pull down with a blue matirx it goes awat does anyone else have a good tip and removing them? Yes yes and i know some of you will say just dont make the mistake but im just curious
Guest GottaWearShades
They're called puckers as far as tinting nomenclature in my area. There's no way to avoid them, because a split-second too much heat in one spot creates them. You have to work them out during the installation process when the film is already applied.
What I find is most effecient to deal with the problem is to spread the pucker along it's length with a wrapped hard card, while applying heat with your heat gun... Essentially spreading the film in the puckered area back to it's normal state before the heat sets the film in place.
