dgmt321 Posted September 29, 2011 Report Share Posted September 29, 2011 I am having really hard time getting the Vinyl to slip and position into place. I spray alot of slip solution but its still very hard to slide it around. Is there an easier way to position the vinyl onto the dot matrix? I am using 751 oracal. Is there a different one that would slide easier? Thanks. Link to comment Share on other sites More sharing options...
alberts316 Posted September 29, 2011 Report Share Posted September 29, 2011 put more soap in your solution. Shouldn't be a issue really Link to comment Share on other sites More sharing options...
TintWizard Posted September 29, 2011 Report Share Posted September 29, 2011 put more soap in your solution. Shouldn't be a issue really the solution to the problem really is that simple I just keep a mounting solution bottle around with 1/3 more concentrate Link to comment Share on other sites More sharing options...
Guest shadeking Posted September 30, 2011 Report Share Posted September 30, 2011 When it comes to heavy dot patterns I use vinyl also, its faster and easier than sanding or other prep methods. I actually don't use lots of soap either. I start by laying the vinyl where the vinyl meets the tint then just smooth it out the rest of the way by hand then squeegee with a black or yellow turbo. Link to comment Share on other sites More sharing options...
robraz Posted October 18, 2011 Report Share Posted October 18, 2011 one side to the other-lay perfect with the line Link to comment Share on other sites More sharing options...
shwusyrtnts Posted October 18, 2011 Report Share Posted October 18, 2011 Same as the others I mix a "heavy" solution and that helps. Shadeking, when you use the yellow squegee does it push around the dots well? I can only get a black squegee to work for me. Link to comment Share on other sites More sharing options...
hawkeyesaob Posted September 20, 2012 Report Share Posted September 20, 2012 I use a mactac felt squeegee.. works really well Link to comment Share on other sites More sharing options...
808 TINT Posted September 20, 2012 Report Share Posted September 20, 2012 I use a mactac felt squeegee.. works really well from Bama.... Link to comment Share on other sites More sharing options...
twotint Posted September 21, 2012 Report Share Posted September 21, 2012 Try xpel gel it works really well. Link to comment Share on other sites More sharing options...
808 TINT Posted September 21, 2012 Report Share Posted September 21, 2012 More slip never hurts. Ask Slimy Stan... Link to comment Share on other sites More sharing options...
