Guest tint325i Posted October 1, 2011 Report Share Posted October 1, 2011 ever done this? got a bit bored one day its actually much easier than taking the door trim off Link to comment Share on other sites More sharing options...
Guest shadowline Posted October 1, 2011 Report Share Posted October 1, 2011 I read somewhere else that some Audi door panels ate designed to be replaced like that didn't know that on the VW that looks insane!! Link to comment Share on other sites More sharing options...
The ///Man Posted October 1, 2011 Report Share Posted October 1, 2011 First jetta I changed a door glass on threw me for a loop. Thankfully most of the answers are on the internet. Link to comment Share on other sites More sharing options...
Guest tint325i Posted October 1, 2011 Report Share Posted October 1, 2011 First jetta I changed a door glass on threw me for a loop. Thankfully most of the answers are on the internet. Ive known how they come apart for a long time just havent tried it before, i think the mk5 golf was the first to be like this, its the only way to change a dropglass, quite alot of the VAG cars are like this you'll easily see all the little black bolts all the way round the door (and 1 little one behind handle), just be sure to put the right bolt back in the right hole because the are not all the same really easy tho, 2mins to remove 2 mins to refit, Link to comment Share on other sites More sharing options...
The ///Man Posted October 1, 2011 Report Share Posted October 1, 2011 First jetta I changed a door glass on threw me for a loop. Thankfully most of the answers are on the internet. Ive known how they come apart for a long time just havent tried it before, i think the mk5 golf was the first to be like this, its the only way to change a dropglass, quite alot of the VAG cars are like this you'll easily see all the little black bolts all the way round the door (and 1 little one behind handle), just be sure to put the right bolt back in the right hole because the are not all the same really easy tho, 2mins to remove 2 mins to refit, The door handle is what gave me a hard time. Link to comment Share on other sites More sharing options...
Guest tint325i Posted October 1, 2011 Report Share Posted October 1, 2011 First jetta I changed a door glass on threw me for a loop. Thankfully most of the answers are on the internet. Ive known how they come apart for a long time just haven't tried it before, i think the mk5 golf was the first to be like this, its the only way to change a dropglass, quite alot of the VAG cars are like this you'll easily see all the little black bolts all the way round the door (and 1 little one behind handle), just be sure to put the right bolt back in the right hole because the are not all the same really easy tho, 2mins to remove 2 mins to refit, The door handle is what gave me a hard time. yeh if u don't know thats there you'd never find it, for those who don't know how to remove handle - theres a gold torx screw in the side of the door inline with the handle, wind it out far enough so it allows you to pull the lock section of the handle out of the door, then a little pull and a wiggle and the big bit of the handle comes out, then you'll see a little torx screw, take this out and it disconnects the handle carrier from the inside of the doorskin the idea behind these doors is if you dent a door you can simply bolt a new skin on instead if replacing whole door, not a bad idea really Link to comment Share on other sites More sharing options...
The ///Man Posted October 1, 2011 Report Share Posted October 1, 2011 First jetta I changed a door glass on threw me for a loop. Thankfully most of the answers are on the internet. Ive known how they come apart for a long time just haven't tried it before, i think the mk5 golf was the first to be like this, its the only way to change a dropglass, quite alot of the VAG cars are like this you'll easily see all the little black bolts all the way round the door (and 1 little one behind handle), just be sure to put the right bolt back in the right hole because the are not all the same really easy tho, 2mins to remove 2 mins to refit, The door handle is what gave me a hard time. yeh if u don't know thats there you'd never find it, for those who don't know how to remove handle - theres a gold torx screw in the side of the door inline with the handle, wind it out far enough so it allows you to pull the lock section of the handle out of the door, then a little pull and a wiggle and the big bit of the handle comes out, then you'll see a little torx screw, take this out and it disconnects the handle carrier from the inside of the doorskin the idea behind these doors is if you dent a door you can simply bolt a new skin on instead if replacing whole door, not a bad idea really LOL VW catching up with America's defunct Saturn Link to comment Share on other sites More sharing options...
Guest Malcolm E Boo Posted October 2, 2011 Report Share Posted October 2, 2011 cool Link to comment Share on other sites More sharing options...
Guest fimmo Posted October 7, 2011 Report Share Posted October 7, 2011 lol looks scary!!! but like the idea!! Link to comment Share on other sites More sharing options...
Guest visualtints Posted November 4, 2011 Report Share Posted November 4, 2011 Hi Is this the similar process for the new shape Audi a6 got one booked in so any advice would be helpfull mate.. Customer don't want his seals cutting he's already done his research so any help stripping down to get the glass out would be appreciated. Thanks Link to comment Share on other sites More sharing options...
