Susuki Kizashi
Devil with bad attitude
Nice car, no door trim removal necessary on any of the doors, just lift the gasket out.
Not a nice rear screen however as it is very bent and fixed 1/4 vent is one of those with the inner rubber tricky to get into as it comes back onto the glass and it is reasonably tight for room to install.
devil
I just did one of these today. Personally I thought it was a very tinter friendly car. As you mentioned gaskets lift out (though they do put up a fight coming up) once you remove the 1 screw behind the door handle. Also I decided to remove the back deck, best decision ever! There's nearly nothing holding it in! Ha! Just remove the rear pillars, pull the clips behind the seats & pop up the 5 white clips from inside the trunk & the thing slides out just like that. Saved me a ton of time I would have spend taping all that felt.
Happy tinting.
    2. 7
    6. 11
    7. 11
