CX-400 problems
Guest 7m34life
Guest 7m34life
I currently use a Roland CX-400 plotter to cut my film. The plotter has worked fine until about 2 months ago I didn't pay attention to how little film I had on the roll and it sucked to plastic roll up and hit the head and jammed the machine. Now when I do longer cuts around 50"-60" it will feed about 3" out and jams and says power off error. I can get around that by going ahead and feeding out how much film I'll need and feeding it back in that way it doesn't have the tension of pulling it off the roll. This morning I went to make a cut with it and it keeps on getting my film wadded up and tearing the film as it's cutting. I run it on 15 cm/s and 120gf on the force just like I always have. The only thing I can think of is last night I was wiping it down and might have moved the manual pen force adjustment on the front of the machine. I did make several test cuts while adjusting the pen force but it's steel screwing up my film. I've already wasted around $100 worth of film by trying to figure it out. Any help would be appreciated.
What settings do you run your plotter on??
THANKS
Does it give you an error code?
you can try to do a master reset on it. See if it clears it up . hold down left arrow, right arrow, origin and power on. It will prompt you to reset eeprom, press enter. You will have to cycle the power and then reset all the force and speed. This factory defaults the machine so all the parameters are reset.
MOTOR ERROR
6-1 TROUBLESHOOTING
Replace CARRAIGE CABLE.
Replace the CARRIAGE ASSEMBLY.
NO
YES
YES
YES
Replace U31 on MAIN BOARD ASS'Y.
Adjust Tool Pressure
Is there cut-line or bad contact in
CARRIAGE CABLE?
Is carraige solenoid OK?
Is there cut-line in solenoid wire?
NO
Is SOLENOID DRIVER IC OK?
YES
Is Tool Pressure adjusted correctly?
NO
NO
NO
YES
Is the Solonoid wire connected correctly? Connect the Solenoid wire.
NO
Adjust MOTOR BALANCE.
Replace F2/F3 on POWER BOARD.
NO
NO
NO
NO
Replace U10/U11 on POWER BOARD.
Is MOTOR BALANCE adjusted correctly?
Is the FUSE blown up?
Is MOTOR DRIVER IC OK?
YES
YES
NO
Is MOTOR CONTROLLER IC OK? Replace U7/U8 on POWER BOARD.
NO
YES
Is +15V regulator IC OK? Replace U14 on POWER BOARD.
YES
NO
Is -15V regulator IC OK? Replace U15 on POWER BOARD.
NO
YES
Is POWER BOARD OK? Replace POWER BOARD.
YES
NO
Is MOTOR OK? Replace the MOTOR.
