Do You Use Short Patterns And If So, Do You Micro Edge
Guest archer69
Guest archer69
Looking into the system. Seems to have a lot of quality features. One thing I have a question about is the short patterns.
The way the manufacturer describes it, almost all of the southern shops use the shorts and northern guys use the longs.
The way I understand it, the short patterns bring the bottom edge to dead even with the gasket if you micro edge. They say if you get it down and hit it with a little heat that it's good to go. And again, this is supposed to be typical down in TX, FL, AL, etc. It seems a little close to me. Maybe I'm interpreting their description wrong?
I'm a northern guy (US anyway), and like a lot of people, I developed most of my techniques in a vacuum early on, so I'm not saying this style of install won't work. It's just that I've always just gone a 1/4" below the point where the gasket hits the glass.
I guess my question is, do you micro-edge the shorts, and do they work well for you in general?
The way I see it, using short cut is akin to installing practices of the 80's.
At least a long pattern allows you to recut microedges that dont line up. Glass edge polishing isn't as precise a science us tinters would want it to be, so there are irregulaties found when fitting pattern microedges car to car.
