2005 Impala Door Seals
Guest jasonbuchanan
Guest jasonbuchanan
Do the seals that go around the window come out in this model? They are just too tight! :)
Thanks in advance.
Jason
Ram Studios
the 2003 impala that I tinted the seal ran all the way down window channel. (I wont pull them when they do that) there is a little nut holding the stripping on so don't just yank it out.
I didn't think they were that tight to begin with..... only problem is the felt/contamination.
I've done lots of these, I've never once seen a seal run all the way down, nor a nut to remove :shrug
Guest tinthoss
2 different year models being referred to here, 2003 and 2005. If I remember correctly one of them has the felt seal that does run way down into the door at the front and rear of the glass. :beer
Guest tint14u
mos definetly is
