Sign in to follow this
Mdog
NEW TITAN PU
there was one in the accessorie shop today, the doors are typical nissan, rubber seals on the sides of the rollups, the side extended cab windows had matrix all around and no latches, the backglass slider had generous amounts of matrix around each window.
ANOTHER EASY one for us :mad
Share this post
Link to post
Guest tintgod
yep..they do have plastic seals....you should felt them...the truck is pretty staight forward...the panel will pop off the top so you can take the seals out...just pop off the cover of the handle on the panel ..there will be two screws in there ...take them out and pull on the top of the door panel...and slide the seal out....easy as that... :thumb
Share this post
Link to post
Contact TintDude tintdude@gmail.com
