2012 Buick Verano
bamh5
The rear deck pulls right out with just flipping down the back seats. I found the doors to be a little bit more time consuming. The plactic around the windows snaps off easy, and there is one screw behind the door handle and two screws behind the door handle grip. I found the hardest part is taking off the plastic pieces that hides the two handle screws. Its only plastic so it can be broken easily. Other than this the car is straight forward.
Guest thebomb
I dont pull a thing, and I tint the litte front window. a little tricky to hand cut but the install is easyer than lacrosse. PS. make a patern for back glass if you do a lot of these
I didn't see any reason to pull out the rear deck.  Third brake light is housed up high like a Pontiac G8.  Easy rear window.  Pulled the door panels nothing to tricky like stated above but those damn front quarters are a PITA to squeegee.
