Chrysler 200
micro-edge
So I did one of these yesterday morning and it sucked donkey balls (maybe cause I was hungover :dunno ). Backglass was easy, you can pull down on the brakelight and pop it out enough to push the water out if you want to cover the light. my problem was the pita front rolldowns, omg! huge side seals will crease the :poop out of the film if you are one that tints the top half then the bottom half after rolling up..I pulled the side seal on the drivers side like I do on impalas and I would really not recommend this, took me 30-45 minutes to get the damn thing back in right.. Best way I found to do the front windows is pull the top panel back and pull the bottom seal, leave the side seals in. pull the whole liner and drop the whole piece in at once to prevent creasing the sides, after putting the bottom seal back in I had to use a hook tool to pull the panel back into place on the seal. Other then the front windows it's not that bad to tint but I was getting :mad yesterday :lol
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
