installing doors with out taking door panels off
Guest fredstinting
Mutoh cutter
I live in a second story apartment and there are two windows in my living room, one facing east and one facing north. My TV is against the wall facing left and my couch is against the north wall right next to the window. In the late morning and early afternoon the sun shines through the east window and casts an annoying reflection on my TV, and sometime around 1 or 2 pm every day the sun gets right in my eyes when I am sittin or lying on my couch even when I am facing the TV. I want to cover these windows with just the right film for solving all of these problems while also making it not look obvious that I tinted them, and I'm not sure what kind I should use because apparently different brands will have different results even if it's the same percentage, could someone help me out here -
or option2 , 40in plotter ( u can cut 80-95% of the full car with it) , and bulk the hoods and larger panels.... -
Windshield protective Film
can you send me a sample so i can test it? -
The coating can be removed by "dry scraping" with stainless single edge razor blades, but it is very time consuming and tedious. The coating comes off like a super fine powder. If done correctly there is no damage to the glass and you can tint it just fine after a thorough cleaning. I scraped the drivers door clean after making the mistake of scratching the coating but I did not scrape the passenger side. After tinting you could not tell the difference between the two. -
Sure looks like auto glass technology is advancing. I remember the coating on Lexus and some Toyota models could be removed with a glass polish. It took some effort to get to the glass itself and that was an anti-fog coating technology. This IR/UV coating is looking like it is more robust. I wouldn't want to be the one experimenting with whatever product to attempt removal of it. The UV rating is 99%+ reduction, but they limit what they say about IR performance to: Mitigates sense of intense heat on the skin ... Controls rising cabin temperatures. The link is to a company that apparently is deep into providing glass with this coating and they certainly limit info. Take a look for yourself. This appears to be something that could/would expand to more brands/models. It sure is going to put a new slant on selling film and installing film to cars. https://www.cgc-jp.com/products/search_category/automotiveglass/ircut.html
