Question about edge prep
Guest 631 Coatings
It is actually quite a bit more effective than a clean surface and alcohol, but the strength of the edge prep depends on how much is used and how quickly the film is squeegeed down. If you apply it liberally and lay the film down within 30 seconds, it will really grab the surface aggressively. If you apply a little bit or wiat a few minutes, you will notice a difference. If you don't lay the film down within about 10 minutes, you will lose the benefit almost completely.
It saves a lot of time on wrapping edges!
