Plotter/Cutter advice!
Hi Guys,
I am thinking of buying a plotter/cutter to cut out pre cut film. Was wondering how would I go about finding the template for each car and model? Does the software have all the
templates or do I have to input it in. Also any suggestions on plotter or cutter would be appreciated. I am just looking something along the line of 30inch maximum.
Thanks in advance
David
Guest Tinter24
you're going to need a 40 inch, why did you think a 30 inch? youll never get back windows out of a 30 except for a few. and if you're cutting out side windows off a 30 your going to have a TON of waste. the program has everything you'll need and theres a monthly fee as well. I think you're going to need to do a lot more research about plotters.
Guest kylecm85
I use tint tek and it is pretty good. Have 99% of the cars I do and are pretty close. Can upsize or downsize the exact measurements if needed. Also have a graph tech 60" plotter. No complaints with it.
