Xw00dsrac3rX Posted December 13, 2012 Report Share Posted December 13, 2012 I was doing a 2013 police interceptor at a dealer the other day and did the rear window like normal but when I cleaned the glass after the film, I noticed a bunch of dirt under the film. Initially pissed off because I thought I was careless in cleaning it, I ripped the film down and re shrunk a new one. This time, before installing I cleaned extra good and then I rubbed my hand over it, only to feel this gritty feeling in one area of the glass again. I used a white scrub pad and went to town on it but still couldnt get it off. I showed the manager and he agreed there was something obviously on the glass but was not replacing the window. I wrote it up and tinted it anyway per his request. MY question is, if anyone has a solution for something like that. There is a X cross bracing that is welded into the bodies of the police models for handling and crush factor, that is different than the standard taurus I was told from the dealer and it may be some kind of welding slag. Obviously cant scrape with blade and white pad didnt work. Cars done and gone now but I will have a few of these to do soon and wanted to see if there may be a solution out there. Link to comment Share on other sites More sharing options...
TomTint Posted December 13, 2012 Report Share Posted December 13, 2012 0000 steel wool is more aggressive than a white scrubbie. Link to comment Share on other sites More sharing options...
Bizzar1 Posted December 13, 2012 Report Share Posted December 13, 2012 I've done a few bodyshop cars with slag on the glass. If it is indeed slag, there's nothing you can do. Even if you get the bumps off there will still be marks in the glass. It almost melts itself into the glass on a microscopic level. No way to clean it. Link to comment Share on other sites More sharing options...
RockyDaz Posted December 13, 2012 Report Share Posted December 13, 2012 Get it all the time, mainly on crusty old work trucks/ tradie vehicles. It can be either weld slag or metal particles from a grinder which hit the glass hot and burn their way in. Only thing to do is to carefully scrape each spot to dislodge particle leaving the 'hole' in the glass ,but it will be smoother once the film goes on Just be very careful with the scraper and be prepared to change blades, those particles hack up the blade making it easy to scratch the glass. Link to comment Share on other sites More sharing options...
tntautoglass Posted December 13, 2012 Report Share Posted December 13, 2012 Get it all the time, mainly on crusty old work trucks/ tradie vehicles. It can be either weld slag or metal particles from a grinder which hit the glass hot and burn their way in. Only thing to do is to carefully scrape each spot to dislodge particle leaving the 'hole' in the glass ,but it will be smoother once the film goes on Just be very careful with the scraper and be prepared to change blades, those particles hack up the blade making it easy to scratch the glass. This. Grinding sparks!!! Link to comment Share on other sites More sharing options...
Blackwolftinting Posted December 13, 2012 Report Share Posted December 13, 2012 Next time try cleaning it with a brick from about 10 feet away. Works for me. Link to comment Share on other sites More sharing options...
lostinbama Posted December 14, 2012 Report Share Posted December 14, 2012 Next time try cleaning it with a brick from about 10 feet away. Works for me. This... Link to comment Share on other sites More sharing options...
Xw00dsrac3rX Posted December 15, 2012 Author Report Share Posted December 15, 2012 Next time try cleaning it with a brick from about 10 feet away. Works for me. I will try this. Link to comment Share on other sites More sharing options...
Blackwolftinting Posted December 16, 2012 Report Share Posted December 16, 2012 Next time try cleaning it with a brick from about 10 feet away. Works for me. I will try this. Link to comment Share on other sites More sharing options...
tint123 Posted December 25, 2012 Report Share Posted December 25, 2012 Would be a good idea for the dealer to notify ford of this, as it is an issue in the assembly process of the car. And you get an individual that is not happy with the tint job, and to be told That it is just a factory defect in the glass and to live with it. That probably will not go over well with customers:...... Link to comment Share on other sites More sharing options...
