2013 Chrysler 300
Guest jasonbuchanan
Guest jasonbuchanan
The problem I had was trying to put the door skins back together the clips on the top and the rubber seal. The bottom of the door went on fine it was getting the top back on. I ended up not taking the other three off and it came out good. But man that was a crappy design to get back together.
Doing one now . 1 screw per door and with a plug puller and gasket remover tool, you pry the panel back a bit and you will see how to release the clips with the gasket remover. Work your way along and the rubber with clips will come out without removing the panels.
(Note: only 2 of the 3 metal clips come out this way on the back windows, the 3rd one located underneath the 1/4 window won't . Just pull the gasket out anyways , once the gasket is out, it's easy to remove the last clip and snap it back on the gasket you just removed.
Once your doors are tinted it goes back in super easy without worrying about panels but you had the benefit of having the gasket out if the way
    2. 7
    6. 11
    7. 11
