Audi A4 Third Brake Light
Guest ShadowTinting
Sit in the back seat facing forward. Then slide your fingers in between the plastic and the glass. Know that that plastic is extraordinarily brittle and if you pull down toward you it will crack. Once you have your fingers on both sides of the plastic pull it back parallel with the back glass. The first bit of slide is the sketchiest part because it seems like it doesn't want to slide, but it will. Then take your 90 pick and detach the cord.
When you put it back in approach it the same way you took it off. You'll have to pull the headliner down a bit to get the last bit of plastic under the headliner. Just remember when your sliding it never never ever pull down forward and backward only. I cracked two of these before I got a great feel for them.
