2012 Buick regal GS
mustangdroptop96
I've done a few Buick regals but for some reason stuck on this car. Would be way easier with the panels off. Can't figure how to pop them off? Back window was cake. Found the torx behind the handles. There is something else holding these panels on? If its that brushed aluminum strip. How do you get it off?
To remove the panels on the 12' and 13' there are 3 torx screws. One behind the door handle, and two behind the door grip (Behind the silver handle part yes) In order to get the grip handle off, you have to pry it off. It just clips on, but make sure you start prying from the middle. Not from the corners or you can break two little tabs off. If you look there is actually a little notch to stick something in to start prying it off.
    3. 6
    5. 11
    6. 11
    7. 6
