back window finger
Guest FORT SLIDER
Guest FORT SLIDER
hey guys when I did a back window yesterday I got this one huge finger on the left side when I did the horizontal anchor then squeegeed up the sides to bring the fingers to the top, I couldn't separate it for some reason, how do I overcome this? all the other fingers were normal but this was huge and I couldn't get it out without creasing it. thanks
Guest Litespeeds
Sounds like you didn't shrink it enough or you need to work on your squeegee technique. Make sure when you squeegee, you are dividing the window into 4 quadrants and push the soap water out towards the corners. Good luck.
Guest Custom Effects
What kind of car is it??? Have you considered 2 pieces? I know we dont like to talk they in here, but it is an option.
Guest thatsnappyguy
I see what your talkin about...standing on the side the car, take the top and the bottom of the film to lift and stretch. use a card on the side and lock it down goin up and down. not side to side.
