2013 Audi S6
mustangdroptop96
I've done quite a few Audis, I always pull panels and the clips usually break luckily they are about a buck a piece. And from other people's misfortune I always cover up the amp in trunk with a bag and stuff with towels, however this is my first brand new s6. The clips are different than previous years, so I'm slowly figuring that out. My question is, has anyone done one of these? The back window was an easy heat shrink just can't figure out the high mount brake light? It is mounted under the headliner. Also the rear panels have a carbon fiber panel around door panels that pop up with 2 torx bits. Then another torx beneath the door pull and the panel popped off. I was only able to locate one torx on the front doors behind the carbon fiber plate and one below the handle but the panel is caught up. Any ideas?
