2012 and up XF folding rear seat, FYI!!
NvrLate
There was a post with instructions on how to remove the rear deck on this generation-Just so you know, the rear seat on the 2012 I just did didn't have release cables to fold it down as some others. These have a very tight brake light, and hard plastic trim touching the bottom of the rear glass along the matrix so i wanted to remove the deck for a flawless install and no cutout. I looked in the owners manual and it clearly showed where to pull the releases, with no noted exceptions, but they weren't there. I searched some Jag forums and found out that starting in Model year 2012 only the XF-R is equipped with fold down. I was able to locate the latches, in the truck, at the top of the seat back, hidden and with no cables attached, and manually trip them and after that it went smoothly.
Some good news, Panels pull back at the top and sweeps can come out quickly. one screw behind the panel and then release the metal clips at the top of the panel, like a lot of BMWs. :thumb
    2. 7
    3. 7
    5. 7
    6. 0
    7. 11
    8. 11
