2014 Range Rover Sport 14MY
tikka
super easy car, remove 1 screw at the end of the door panel then pop the top back.
The gasket is in 1 complete piece with the sides so you will need to slice it to get just the bottom out.
On the rear if you remove the molds you need to plug the cut outs in the metal with cloths or something otherwise the water will run into the roof liner.
All n all get as many of these as possible. :yep
I just bought one and have discovered a problem I encountered on another. For some reason, the window doesn't always roll up the same on the drivers side. Even when you hit up on the switch after roll up.
Sometimes you have a quarter inch gap on the bottom and sometimes not. For those who don't take anything apart: Stuff some extra down.
    2. 7
    6. 11
    7. 11
