I think it was a 300C
GTint
Howdy dudes.
Had a walk in customer a few days ago.
Today got the call he wants me to tint it.
I think I'm getting confused as to what the vehicle is?
I think it's a 300c? I do remember its a 4 door.
Had the HEMI 6.4 badge on the front fender.
Rear screen I remember had like half inch thick micro dots.
Maybe it was a charger?
Are the 300c, charger etc doors pretty easy to strip?
Two big fully tattooed guys rocked up in it, so I don't want to stuff this up :)
Any advice on either cars would be much appreciated!
Cheers.
pretty simple car either way.  If it is the 300 and the brake light is in the rear deck then I would pull it for sure.  Rear seat folds down and there are 10mm bolts on the bottom of the outside edges on the bottoms.  The tops are a spring clip that you need to hit with a screwdriver or bone tool...press down from the deck edge and it will release it.  Don't just try to pull them out or you will break or at least stretch them out badly...
I pop the christmas tree plugs and then bend and yank the rear deck out....
door panel should be bend back top and yank the sweep...
