Dodge Caravan
Shelby Ford
Hello all, I was wondering how you guys were doing the roil ups on the rear sliding doors. It looks like it has the thing at the back that covers some of the window. It looks like a real nightmare to get film behind there. Any tips?? Thanks in advance!!!
they are actually very easy.  The plastic part on the back comes off.  The clips like to stay on the door metal though.  Use a hook to open the clip up to release it then put it back in the plastic.  The panel will pop back and the sweep comes out after you have the pillar plastic off.  There are some screws at the door handle inside that you need to pull as well as the trim panel around the handle.
You are a 12 volt guy so pulling panels should be easy.  Just get the trim around the handle off and the rear plastic then pull the top of the panel back.  Very simple once you do the first one.
Film can slide in so easy after that...
Really cool!! Thanks!!
      What did you tint today?
    2. 4
    3. 4
    4. 4
    5. 4
    6. 4
    7. 1
      Beginner Tinter
    8. 0
      SIGNALS DEFENSE - EXPERIENCED WINDOW TINTERS NEEDED - COMMERCIAL
