Thu9life Posted August 31, 2014 Report Share Posted August 31, 2014 I use the clear max it's softer and glides better Link to comment Share on other sites More sharing options...
SolakTint Posted August 31, 2014 Author Report Share Posted August 31, 2014 how it is with removing solution? does it remove enough? Link to comment Share on other sites More sharing options...
Tint Wife Posted August 31, 2014 Report Share Posted August 31, 2014 Blue. I use the clear max it's softer and glides better I give clear to my trainees and then progress to blue.... Just saying. Link to comment Share on other sites More sharing options...
Guest matriXtints Posted August 31, 2014 Report Share Posted August 31, 2014 Yellow turbo for cleaning blue max for squeegee Link to comment Share on other sites More sharing options...
Thu9life Posted August 31, 2014 Report Share Posted August 31, 2014 I reckon the clear and blue gets the same amount of water out I always clean the window one last time to make everything is clean and all bubbles are gone Link to comment Share on other sites More sharing options...
Guest matriXtints Posted August 31, 2014 Report Share Posted August 31, 2014 I reckon the clear and blue gets the same amount of water out I always clean the window one last time to make everything is clean and all bubbles are goneIn previous posts you stated that you tell customers to wait 14 days for bubbles to dry out have you got better in the last week lol Link to comment Share on other sites More sharing options...
Glass Tinting Supplies Posted August 31, 2014 Report Share Posted August 31, 2014 I will use the blue max for auto installs, and the blue power blade for flat glass installs. I have actually found that a 6" power blade will remove more water than a heavy duty 8" blade. The white blade is a good density for curved rear screens. Or for when the temp gets over 40 deg.. I hear that the 8" orange fusion handle is good for flat glass installs also.. Cheers Link to comment Share on other sites More sharing options...
Ryker Posted August 31, 2014 Report Share Posted August 31, 2014 I use the orange crush for both auto and flat. I have the fusion 5 long handle for auto and the fusion 8 long handle for flat glass. I used the blue max and the blue channel blade before but since getting the fusion handles I don't even want to use the others. Link to comment Share on other sites More sharing options...
wickedtint Posted August 31, 2014 Report Share Posted August 31, 2014 I haven't tried the Orange crush. What do you like about it? How is it different from blue max? Link to comment Share on other sites More sharing options...
Ryker Posted August 31, 2014 Report Share Posted August 31, 2014 it is just slightly softer but what I love is the edge seems to last longer than the blue max blades I was using. I get 3 to 4 times the life out of the orange crush for auto. Link to comment Share on other sites More sharing options...
