2015 F-150
autoimage
Can i ask a noob question on these. when you guys cut these patterns, do you cut the sides and shift, then cut the bottom? Or do you cut the bottom first then cut the sides and shift? Less than a year and have yet to do this style f150. I think cutting the sides first then the bottom will give the perfect allignment am i right? Thanks alot
  • Replies 32
Tinting a new f150 today in SolarFX. Get to try out my mirror tool for the first time
:lol  You probably won't need it on the new-new ones.  I think they went back with a set screw.  :thumb
Yeah,, most of them are around $450 and the mirror is over $100 if you brake anything on it.   :nervous
AND REMEMBER = ALWAYS WD-40 the button and the button part of the mirror itself with a Q-tip, before you put it back on.   :thumb2
On the new F-150 pry the bolt cover from the front it pops right off I've done about a half dozen of them.
There is also a bolt under the sail panel up by the mirror
. Anybody got a video of getting this cover off? I've pried on two different ones with no luck.
