2015 Camry
nep3
If I remember right the sweeps don't pull out. But you can roll down the window and pull the top of panel back enough to slide the tint in. If you pull the top of the front doors back too far you will end up having to remove the front 2 door panels.
If you're in the backseat facing the brake light it slides to the right then pull it towards you. The wiring for the light isn't very long so it can be a pain to plug back in.
