anybody used one of these
Guest naughtydog
Guest tintgod
I think that is for res.and comercial tinting..bu I could be wrong...never used one....but is dosnt look like you would get much pressure with it... :rollin
Guest Sprinter
thats one of the first tools I was given when I first started tinting, it made quick work of a late 80's camero rear window!
lately a few years ago I was still using them to do my clean up cuts cause you can see through it, they also have a bigger one that is a foot long with an alluminum handle and it would certainly make quick work with flat glass. jsut keep them sharp or sanded to be safe!
Guest SQUEEGEE
I ordered one outta curiousity and can tell you that it's hard to find an exact use for it for either Flat or Automotive tinting. I primarily use mine for glue extration on the dot matrix because it is very pliable and comforms well to the contours of the the glass specifically on the upper corners.
    2. 7
    3. 7
    5. 7
    6. 0
    7. 11
    8. 11
