2015 lincoln navigator
nep3
Thank you for the response, I still ended up pulling the sweeps. For the panel pullers, the removal is same as the 2012 models. one 7mm bolt behind the door handle under a cap, one screw under a cover on the back edge of the door panel, two 7mm bolts in the pull handle under a cover, and two 7mm bolts on bottom of door panel. After removing these, pull the door handle bezel out by popping the front loose then it will slide out. From this point, pop the top ONLY of the sail panel and then lift up on the door panel and it will come off. Do not pull on the bottom of the sail panel as it is in the door with a hook type latch. Hope this helps others.
    2. 7
    6. 11
    7. 11
