2016 Hyundai Sonata Hybrid
RecklessReflections
Just did one of these vehicle yesterday for a Hyundai dealership.
Very simple and straight forward vehicle to tint.
Gaskets come out very easy and in seconds, I myself don't even need to take off the screw behind the door handle plate; I feel it's not necessary and cuts down on overall installation time. But, for those who want to remove the screw for comfort, by all means go at it.
As you can see even though there is a window screen attached to the panel theres enough space to pull the panel back and grab the gasket to pull it out, if you don't take the screw out just shoot some solution under the gaskets brim where it'll slide upon the metal frame to make putting the gasket back with ease. Just make sure to remove the plastic triangular piece on the edge of the door/panel before trying to lift and pull the panel.
As for the back window, simple shrink. shouldn't give you too much issue.
However, I don't know how many of you check the luggage area for any wires/fuses ect. But I seen the battery is located on the right hand side and looking further in is a wire harness, I myself don't even risk the chance of not covering it as it only takes a few seconds.
The doors them selves do not require any pre shrink, especially if you're pulling the gaskets out. I found that installing them there weren't any aggressive fingers.
Overall easy car!
Cheers  :beer
      Contravision
    3. 29
    6. 3
    8. 3
    9. 4
