Little tip for newcommers
Some times you come across frost film vinyl. You'll start getting frustrated scraping it. Try scouring the film in vertical strip and peeling it slowly.
http://sendvid.com/jhw1zqxf
Looks like bronze Matt......try that with DC or FC.... It's miserable. Strips sometimes help but it still sucks
Might want to add to make sure to use SS blades if scouring the film to help reduce the risk of scratching the glass.
I do not use the blade strait on when cutting the film into strips, I always cut with the blade at a 45 degree angle so not to scratch the glass.
:ditto  As long as the slope of the blade doesn't go above that all should be good. My slope when scoring is less than 25 degrees. I have seen scratches made by SS blades all because they were dull or (microscopically) corroded at the edge.
      Peanut Killer
    2. 3
      Peanut Killer
      OG tinter
    4. 1
      OG tinter
      Peanut Killer
    6. 0
    7. 6
      Tack Solution When Vinyl won't lay flat
    8. 6
    9. 6
    10. 3
      Peanut Killer
