Laminated Front Door Glass
  • Replies 38
i use a mini blow torch on the outside if i get a flip line. just heat it slowly and no problems. to hot to quick can blow it.
had an old bronco i tinted and did not know they replaced the quarter with laminate and broke it. no problem shrinking the
film on the outside. I use a ts-8000 torch with map gas to shrink windsheilds. mini for touch ups or a torch lighter 3flame.
just heat it slower and not one small spot on lamminate and your fine.
Smartie2shoes should chime in on film absorption levels and that type of glass
Easy to look up on llumartech. Use F2G to determine what is safe on clear laminated and go look at those film performance values. You will find anything over 55% absorption is not recommended. AIR 80 = 45% SA. Roll the dice pretty much at 05's and 15's.
FWIW, IMO, laminated glass in a FG situation is far more susceptible to breakage due to S.A due to how it is typically cut. It's usually mangles around the edges with clams all over them. Laminated glass in auto tends to have nice polished edges.
Guest temonunez26
:yeah And for noise reduction.
When heat forming use the snap method (lift and heat 'dry' bottom edge only) and there's no worries. :thumb
Yeah, but more concerned on how much heat can be used if a spot on the outside needs to be heated? Has anyone had a newer door glass(say 2009- on) break on them from heating the outside?
Yes 2009 f350 right front passenger glass. Spidered/ Cracked while using torch.
    2. 7
    6. 11
    7. 11
