Global film
  • Replies 29
I'm thinking of changing to Global film. My supplier has just started stocking NR QDP , NR QD and HP charcoal. Anyone got any experience with these films. Please discuss. Currently i use suntek Carbon which is more expensive by at least £60 per roll.
Hey Note,
I wouldn't be shopping on price...
Use the search button at the top of the page..
I would be surprised if you found a single post that says that Global has failed or let someone down... It seems very solid.
Cheers.
Only negative I have with global is it is not "made in the USA"
I have used it for over 8 years and have no complaints and have not seen a warranty issue. I have seen a film failure on Llumar ATR in this time frame.
You won't have any problems with global. I've been using the hp for 6 or 8 years. I've had two failures in that time which was off of the same roll. The scratch coat peeled off on two roll downs separate vehicles. I was refunded the cost of tint and installation. No other problems periods. I like working with the hp more than both of the others due to the thickness. You should at least try it to see if you like it. Hope this helps.
Think i will go with the HP. What's the NR Quick dry plus like?
The qdp feels thin to me and has a brownish color to it. I know a lot of guys use it and like it. It's just not my preferred choice. Here's a few I did with the hp.
post-29693-0-08455400-1445561752_thumb.j
post-29693-0-60581600-1445561765_thumb.j
post-29693-0-01123600-1445561782_thumb.j
      Peanut Killer
    2. 3
      Peanut Killer
      OG tinter
    4. 1
      OG tinter
      Peanut Killer
    6. 0
    7. 6
      Tack Solution When Vinyl won't lay flat
    8. 6
    9. 6
    10. 3
      Peanut Killer
