Mk 5 golf rear window
steveyb109
Also I pull a couple fingers from the top and bottom to the side while shrinking then once I've finished shrinking the top and bottom I move those fingers back to finish shrinking. Also helps if you shrink a little at a time all the way across. By this I mean instead of shrinking fingers top to bottom before moving over I equally shrink all the way across going back and forth. That way the trouble areas have a little time to cool off, preventing creases.
:yeah
plus i do the soap method
Hello All,
Speaking of rear windows, what kind of lights/lighting method would you recommend to expose the matrix???
i am using a small LED light and i hate having to stop to keep adjusting it.
Thanks,
Mike
i use a halogen lamp in some cases it will light the whole window so you dont have to keep moving it
Hello All,
Thanks,
Mike
Picked one up from home depot for $13 bucks. Worth the investment. Thanks for sharing.
