Creases when shrinking
  • Replies 20
I concur, sounds like you are rushing it. Try using a glove to "coax" it down and heat ahead of the area you are shrinking.
If you are anchoring your sides in an "H" pattern, try just anchoring the middle and let the side float free. That can reduce the stress points and allow you to feed the excess in as you shrink.
