Porsche Macan
lambchop13
Not done one of these before so i thought i'd share….
tailgate's a bit tight so i removed the rear trims(easy peasy)
door card removed has to be the easiest ever, torx screw behind handle pull, and the whole card lifts up,i rested it on the bottom "tags" to save unplugging all the cables which still gave good access to the glass.
the weather strip is all one piece so just pulled it out of the way..
ps the glass is soft so may score when cutting template BEWARE
post-19957-0-68810300-1451501408_thumb.j
