2015 Ford Fusion interior door handle bolt cover
carolinatinter
  • Replies 40
I do lots of these fusions , all 4 plastic covers and all 4 bolts with a 10mm on a drill are out in under 1 minute for easier sweep removal . A little hook tool is all that's needed with a good quick pull for the plastic cover on the "grill" side and it'll never break the tabs
Thought I would add a couple of pics since I was just dong this vehicle .
This is where to pry with a flathead screwdriver :
These are the tabs that break if you don't pry where illustrated above :
And this is the clearance payoff for a clean install with at one simple removal which takes a grand total of 30sec
Not "THE" way , but "A" way for a clean install .
Nice :thumb
Not really an answer to your question but we don't take the panels off of the Fusion.  You can pull the top of the panel enough where you can pull the weather stripping out.  Use a hook tool to make it a little easier.  Saves a lot of time and broken peices.
    2. 7
    6. 11
    7. 11
