Guest naughtydog Posted April 4, 2004 Report Share Posted April 4, 2004 I cant get the hang of the unger pro handle. Anybody got any tips on fitting say a blue max squeegee into one, I ended up breaking the clip you push trying to get it in. Is it best to tighten the screws up gently and then flip the clip or what. Think I'll have to go with an orange crush handle or something as these suckers get me every time. I ended up just winding the screws tight to hold the squeegee Naughtydog Link to comment Share on other sites More sharing options...
Guest tinterjim Posted April 4, 2004 Report Share Posted April 4, 2004 Don't worry about snapping the clip, I usually cut them off anyway. I just use the screws and tighten down my blue max. Link to comment Share on other sites More sharing options...
Guest thetintshop Posted April 5, 2004 Report Share Posted April 5, 2004 I didn't have any problems mounting mine. like tinterjim said, don't worry about the clip, just tighten the screws down. Link to comment Share on other sites More sharing options...
Guest naughtydog Posted April 5, 2004 Report Share Posted April 5, 2004 aagh...good. I thought it was just me. Seems like a poor design there, I've never had one work right yet. ND Link to comment Share on other sites More sharing options...
Guest thetintshop Posted April 5, 2004 Report Share Posted April 5, 2004 not really a poor design. it just wasn't meant to hold something as thick as a blue max. Link to comment Share on other sites More sharing options...
Guest naughtydog Posted April 5, 2004 Report Share Posted April 5, 2004 makes sense now nd Link to comment Share on other sites More sharing options...
VWaholic Posted April 6, 2004 Report Share Posted April 6, 2004 if you really tighten the screws down you might want to grind them off so they don't stick out as much on the other side. Link to comment Share on other sites More sharing options...
TintWizard Posted April 6, 2004 Report Share Posted April 6, 2004 some of the handles were made different than others..I lossened the 2 screws a bit, took a hammer and tapped the "teeth" of the unger into the blue max, then pushed down on the clip fo a tight fit without damaging the clip...by tapping in the teeth, it takes off th "thickness " pressure when setting it for the first time Link to comment Share on other sites More sharing options...
Guest thetintshop Posted April 6, 2004 Report Share Posted April 6, 2004 some of the handles were made different than others..I lossened the 2 screws a bit, took a hammer and tapped the "teeth" of the unger into the blue max, then pushed down on the clip fo a tight fit without damaging the clip...by tapping in the teeth, it takes off th "thickness " pressure when setting it for the first time this is what I did. Link to comment Share on other sites More sharing options...
Guest tint_master Posted June 22, 2004 Report Share Posted June 22, 2004 some of the handles were made different than others..I lossened the 2 screws a bit, took a hammer and tapped the "teeth" of the unger into the blue max, then pushed down on the clip fo a tight fit without damaging the clip...by tapping in the teeth, it takes off th "thickness " pressure when setting it for the first time That's what worked for me too. I jsut loosened the screws enough to get the latch to barely close on the blue max. It's never gave me any problems!! Link to comment Share on other sites More sharing options...
