Plastic Windows Fiat 500L
shannon
Make a template, do not cut on them. Oracle 8300.  Cut them tight, the inside has a little rubber and you cannot cut if the pattern is to big.  Heat from inside is ok at a distance and move the gun fast.
Where can we buy the material (Oracal 8300 vinyl) is there a distributor that you would recommend? If not, do you have a couple small pieces I could buy from you? Have you ever removed the the Oracal 8300 vinyl? If so, did it leave an adhesive? Thank you for your help. :)
      Contravision
    2. 29
    4. 3
    6. 4
    7. 3
    8. 4
    9. 3
      New tint. Not happy
    10. 3
