2016 BMW M5 Door Panel Removal
Midtown Houston
This is pretty easy car to remove the sweep.....I know I put the title as door panel removal...but you don't need to remove the door panel on this car to remove the sweep.
Toward the front of the chrome trim is a  space that you can put 2-3 finger and pop it out with your finger.  This chrome piece can be wood trim or what ever color trim depending on the upgrade.  Pop it off and pull toward the front of the car due to a hook toward the back of the trim piece. If you don't do that, the back part of the trim can break and you will need to buy a new trim piece. There is only 1 torx screw to remove and top door panel pop off....remove sweep and do your magic...
post-37569-0-27259100-1461983293_thumb.j
post-37569-0-19553400-1461983310_thumb.j
post-37569-0-38483600-1461983355_thumb.j
post-37569-0-07008400-1461983371_thumb.j
post-37569-0-13475900-1461983381_thumb.j
post-37569-0-65614100-1461983402_thumb.j
post-37569-0-57173300-1461983414_thumb.j
post-37569-0-91863000-1461983439_thumb.j
