2016 sonata 4dr sedan rear dash
tonysa
How do  you get behind the 3dr brake light without getting particles in the film. Theres almost no room to slide the film in.
The rear fuzzy dash touches the window and is causing contamination.
I posted a totw on using window tint pieces to mask the bottom of rear decks on cars.
I use scrap pieces and go 4 to 6 inches up the window. Normally I split into 2 pieces but sometimes 3 across.
Cut the bottom to match the curve of the bottom. Wet the film side, peel liner, place adhesive side away from glad onto window, slide down window to bottom, get film of window and press down onto the deck.
I put the right side on first as I squeegee from the left to right when cleaning the bottom.
:facepalm2  :facepalm2 REALLY? all that work on a 2016 Sonata just to get behind the 3rd brake light?
Just tint it, no need to remove anything for that back glass.   Or learn to Reverse Roll it...
      Contravision
    3. 29
    6. 3
    8. 3
    9. 4
