04 F- 150
it was easy.....you can remove the gasket without removing the panel...2 screw and it pulls back :lol
(I still prefere the older styles though)
I always like removing the gasket whenever I can to get the film way below it...even better if you can get the gasket (rubrail) out without pulling panel :rollin
where are the screws at WIZ? are they in plain site or hidden?
right where the handle is to open the door..they are hiding behind an easy to remove plastic peice I think it was two 8mm bolt screws then just pull back...rubrail pops out...the benifits of removing the panel...without removing the panel :jerkit
**when putting back..I used a flathead screwdriver to lift in the plastic hook thats located in the corner that covers up the mirror apparatus (sorry, no pics) **
why you want to remove the gaskets? :jerkit no need on those. :lol6
I always pull the rubrail if it's easy enough..then the film is below it ..I don't mean the whole gasket..just the rubrail/gasket :thumb
    2. 1
      Contravision
    4. 29
    6. 3
    7. 3
    8. 4
    9. 3
