TTS Posted June 9, 2016 Report Share Posted June 9, 2016 Guess it would depend on what steamer you were using .... If it would get hot enough Link to comment
flipflopless Posted June 9, 2016 Author Report Share Posted June 9, 2016 Guess it would depend on what steamer you were using .... If it would get hot enough its a 1300w jiffy steamer we use it to remove film Link to comment
jh812 Posted June 9, 2016 Report Share Posted June 9, 2016 By the time you get it shrunk you probably could've walked to the nearest auto part store and bought a heat gun. Link to comment
flipflopless Posted June 10, 2016 Author Report Share Posted June 10, 2016 i have heat guns thats isnt the issue. actually there isnt one i just wanna know if it has been tried or done. Link to comment
waxworkz Posted June 10, 2016 Report Share Posted June 10, 2016 If you have a steamer and tint, why don't you try it and report back? Link to comment
TTS Posted June 10, 2016 Report Share Posted June 10, 2016 I don't think the steam out of the jiffy will be hot enough ... Link to comment
TTS Posted June 10, 2016 Report Share Posted June 10, 2016 I remember reading a few years ago the film begins to shrink at like 240 degrees f. Link to comment
F1windowtinting Posted June 10, 2016 Report Share Posted June 10, 2016 Get intoxicated and try it Link to comment
SuperSetKing Posted June 10, 2016 Report Share Posted June 10, 2016 Film starts shrinking around 100 to 140 depending on the poly mfg. 240 is melting zone. Film shrinks at the temp it was stretched at as well as the temp of the dye vat if not an extruded film. My serious question is.... Why would you even attempt this? If you use it to strip film then I would assume you know boiling water burns. Sounds painful to me. Lastly heat guns that shrink well have about 1000 degrees and a lot of cfm. The steamer has neither of those qualities. But seriously, I'd pay good money to watch you try. So film it if you get a wild hair. Link to comment
