derf27 Posted June 14, 2016 Report Share Posted June 14, 2016 Hey everyone. I get usually little dots in the top corners of door windows. Why? Or how do i eliminate that? And also sometimes along the edges. Im guessing from the gaskets? But how do i do a better job? I usually go over em and clean em up to 3 or 4 times before i install it.. Link to comment Share on other sites More sharing options...
Ryker Posted June 15, 2016 Report Share Posted June 15, 2016 Are you touching the adhesive soar if the film with your finger tips? If it is in the top corners I would bet you are. Link to comment Share on other sites More sharing options...
Tintguy1980 Posted June 15, 2016 Report Share Posted June 15, 2016 http://www.tintdude.net/contamination.html Link to comment Share on other sites More sharing options...
derf27 Posted June 16, 2016 Author Report Share Posted June 16, 2016 Thank you smarties Link to comment Share on other sites More sharing options...
noteboom80 Posted July 12, 2016 Report Share Posted July 12, 2016 I used to have real trouble with roll down windows. I've stared tapingbthe felt seals with masking tape and thus seems to have eliminated my problems. I also found i clean less than i used to. Think sometimes you can over clean which courses problems. I razor, then squeegee the glass then run a squeegee down tyecsides followed by a final squeegee on the glass then good to go. Link to comment Share on other sites More sharing options...
quality tintz Posted July 17, 2016 Report Share Posted July 17, 2016 (edited) Tape it scrape it towel it. Squeegee. Spray down and install clean out bottles daily with hot Water Edited July 17, 2016 by quality tintz Link to comment Share on other sites More sharing options...
ryantint Posted October 17, 2017 Report Share Posted October 17, 2017 Wash Floors Link to comment Share on other sites More sharing options...
Tint Slayer Posted December 6, 2017 Report Share Posted December 6, 2017 When you take the liner off you may be spraying in such a way that stuff is running onto film from outside of the film. Whatever you peel from clean a good area wider than film. Link to comment Share on other sites More sharing options...
shadytints Posted December 8, 2017 Report Share Posted December 8, 2017 so many solutions for the various problems we encounter. easy fix for ya,,,, providing you don't touch the adhesive. top corner debris is typically from the top of the window. front and back gaskets having dirt near flip line on 2 stage is a excessive water problem combined with gravity. will describe my process and *** the steps that cause your issue. old or dirty felt gaskets I tape and scrub old rubber ones before I start. cars are pulled in with fan on high, recirc and defrost on. car filters remove dust in car and heat glass to ease shrink and avoid condensation issues. with window up, wet squeegee sides, and put film on sides. gets dirt off glass and keeps dirt from landing on glass in dirty shops. powder BG feeling for rocks or sap. horizontal wet line and cover with film. cut to fit, so less shrink and can shrink to 1/8 inch of side. knifes out, cut sides to fit . map gas ts8000 snap sides(top, prevents peelin, ask) and shrink BG. my film is stretchy, I slightly over shrink because the inside of the window is smaller with more curve. I start passenger rear then front ending on drivers door removing key to save battery and place keys on shield. wet door outside including upper gasket (window still down 2 inches) round corners, place back on door. wet door inside and roll up. blade bottom flush gaskets side and bottom, roll window down couple inches. wet and blade top 2 inches, then wipe top of glass with towel, wrap ez or tri-edge check front and back gaskets for dirt. ******spray top front and top back 2 inches***** to remove dirt the towel cant reach. light mist window squeegee border to border making sure water goes down, not over top of glass. squeegee front and back 2 inches down. light mist on glass no water running, peel 3/4 release and again mist. pulling release creates vacuum, car can be dirty as long as its wet. mist prevents dirt from running in to film from car. apply film to top of door couple inches, long slow taper to prevent pinch/flipline. squeegee water up and over top watching top for water running down to front. *****prevents water flowing down sides making dirt trails at flip*******. roll window up, rinse down and out lower section, pull rest of release sheet and tuck extra 1/8 in gasket, carefully squeegee the smiley (from top snap) out, wipe down car, most has already dried, damp towel all ya need. vid on the youtube Link to comment Share on other sites More sharing options...
Tint Slayer Posted December 8, 2017 Report Share Posted December 8, 2017 12 hours ago, shadytints said: so many solutions for the various problems we encounter. easy fix for ya,,,, providing you don't touch the adhesive. top corner debris is typically from the top of the window. front and back gaskets having dirt near flip line on 2 stage is a excessive water problem combined with gravity. will describe my process and *** the steps that cause your issue. old or dirty felt gaskets I tape and scrub old rubber ones before I start. cars are pulled in with fan on high, recirc and defrost on. car filters remove dust in car and heat glass to ease shrink and avoid condensation issues. with window up, wet squeegee sides, and put film on sides. gets dirt off glass and keeps dirt from landing on glass in dirty shops. powder BG feeling for rocks or sap. horizontal wet line and cover with film. cut to fit, so less shrink and can shrink to 1/8 inch of side. knifes out, cut sides to fit . map gas ts8000 snap sides(top, prevents peelin, ask) and shrink BG. my film is stretchy, I slightly over shrink because the inside of the window is smaller with more curve. I start passenger rear then front ending on drivers door removing key to save battery and place keys on shield. wet door outside including upper gasket (window still down 2 inches) round corners, place back on door. wet door inside and roll up. blade bottom flush gaskets side and bottom, roll window down couple inches. wet and blade top 2 inches, then wipe top of glass with towel, wrap ez or tri-edge check front and back gaskets for dirt. ******spray top front and top back 2 inches***** to remove dirt the towel cant reach. light mist window squeegee border to border making sure water goes down, not over top of glass. squeegee front and back 2 inches down. light mist on glass no water running, peel 3/4 release and again mist. pulling release creates vacuum, car can be dirty as long as its wet. mist prevents dirt from running in to film from car. apply film to top of door couple inches, long slow taper to prevent pinch/flipline. squeegee water up and over top watching top for water running down to front. *****prevents water flowing down sides making dirt trails at flip*******. roll window up, rinse down and out lower section, pull rest of release sheet and tuck extra 1/8 in gasket, carefully squeegee the smiley (from top snap) out, wipe down car, most has already dried, damp towel all ya need. vid on the youtube You ever bottom load? Link to comment Share on other sites More sharing options...
