DMC
Guest thetintshop
will this film lay flat once installed?
21 members have voted
  1. 1. will this film lay flat once installed?
    • 1-Yes
      13
    • 2-No
      8
Guest thetintshop
let's test everyone's ability to eyeball a piece of heatshrunk film and tell whether or not it is ready for install, without having to wet check first
I did a wet check, and took a picture of the result just for this test. and I will post the pic tonight.
once you've been doing it long enough, you can tell just by looking at it.
don't ask what type of car it is. :jerkit this isn't a test to see if you can remember how to handle a certain back glass.
the pic is in the next post.
  • Replies 44
Guest SQUEEGEE
By looking I'd say no. I had a short lived career as a powder shrinker myself and if I had horizontal lines across the film like that I'd most assuradely muck it up and crease it badly squeegeeing it out on the install.
:jerkit
Guest thetintshop
everything you said was fine, except that last part. you worded it perfectly, TOO perfectly. somebody might get a hint as to what type of car it was, and that would would help determine their answer.
